| | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | So got some minor oil leaks on the newly redone 235, one is the fuel pump seal which I might actually fix, the other is either oil pan or rear main seal and I probably won't worry about those cause it's so slow it doesn't really matter I don't think...I used a gasket set as well as rtv silicon on each side of the gaskets. I've never seen and inline Chevy six, not leak from somewhere not that I've seen a ton of them but I'm starting to think it'll leak from somewhere no matter what.
Also some milky oil crap (not much just a drip) comes from my breather tube, but there not really a sign of water in the oil, is this just condensation or something? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Yes, it probably is condensation.ðŸ›
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Fuel pump leaks are often from people using split lock washers on the mounting bolts. Oil will wick out the bolt threads and through the split in the washer.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Ohhh ok thanks Dave, I dunno if I used em or not but I'll check | | |
