2 members (Otto Skorzeny, 1955 1 Series), 67 guests, and 2 robots.
Topics128,172
Posts1,057,105
Members48,463
Any issues with running a '59 Saginaw 4 speed transmission with a 350 V8 versus the original 283 V8? I know the Saginaw is strong and I believe should be able to handle the increased horsepower and torque. Thanks for input.
I have a 1970's (?) Saginaw 4-speed in my '56 3100 with a mild 350 and it work fine, but I don't abuse it either!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Mike, what difficulty or mods did you have to make to get the Saginaw in there. I've got a Saginaw out of a '69 chevelle that I'd like to put in my truck, which is a '55 series 2 3100.
Jim
1955 Chevy series 2
6 cylinder, 3 on the tree
Short bed, step side
I didn't have to do any real modifications to put the 4-speed Saginaw (Camaro trans) in my 1956 3100. My 350 has a V8 truck bell housing so I'm hanging the Saginaw off the back just like the SM-420's were done. I installed a T&F Shifter that puts the shifter in the original 4-speed location with only a little trimming to increase the floor hole opening.
T & F Shifter
31799 Chestnut Lane
Lebanon, OR 97355
541-451-1929 Mark
I don't think he has a web site...
Mike B smile
Last edited by Mike B; 02/05/2018 6:08 PM. Reason: image fail and then I got it :)
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
A few of my competitors on the dirt tracks ran Muncie 4 speeds behind beaned-up 350's with few, if any problems. Hammering on and off the throttle at 3-6K RPM several times a lap with the transmission in 2nd. gear had a habit of showing up weak spots pretty quickly. The aluminum case Muncie transmissions would handle 2nd. gear that way, but if somebody tried to use 3rd. with a lower geared rear end, the case would split wide open after a few laps. The Saginaw has a cast iron case, and appears to be much heavier and more durable than the Muncie. That's a misconception - - - -apparently the gears and synchronizers are a little weak.
I know this thread was originally started 16 months ago and the last post was 14 months ago. I only wanted to say that interior pic shows a clean setup. Nice work.
Professional Novice
Can the original emergency brake be kept when using the Saginaw?
I just pulled my SM420 which had a dowel about the diameter of your thumb that the Emergency brake lever pivoted on. The Saginaw of course lacks this provision.
1950 GMC 250 Pickup
1965 Mustang Convertible
1972 K5 Blazer
1973 Buick Centurion 455 Convertible
Thanks for the compliment Frank!
Buckkoo...what year and series truck are you asking about???
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
