5 members (Steelonsteel, Hotrod Lincoln, 55shaker, ShopRag, 78buckshot), 100 guests, and 1 robot.
Topics128,035
Posts1,055,552
#124607 02/16/2007 7:10 PM
4D6
Offline
Apprentice
Apprentice
I am working on a '45 1/2 ton. The back of the cab has an area where the top and bottom panels overlap. This is right on the "stripe" part. It looks like a common rust spot. Where do you find patch panels for this area? What should you do to prevent future rust in there?
Experience is the ability to recognize a mistake when you make it again....
#124608 02/16/2007 7:24 PM
Junior Member
Junior Member
2 Offline
Jim carter sells patch panels for the cab area that you are describing
