2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
'50 3100 216 - see photo, this eng is coming out and will be replaced with a 235.
My question is (out of curiosity) is this the way a number "1" would have been stamped
in the Serial number. Looks strange to me. The entire Ser # HBA943391 (? last digit 1 ?)
In your case it probably is. BTW I could be wrong but your engine may be a ‘49. I have been wrong 2 or 3 times already today. Just ask my wife.🤷🏼‍♂️
Thanks Martin,
I'll probably research that a bit farther, can't see the casting date, but the Eng I.D. (3835497) states '50-'51. Oh well, it'll be coming out shortly.
Jim
Update:
HA...jus looked up a different Eng I.D. site (inliners) and it says....'42-'53
FYI: the other is "znet".
3835497 is a Block Casting Code for a 216 - 1948-1951
Engine Serial Number: HBA943391 or HBA 94339I (the "I" stamp was used "interchangeably"/mistakenly for the "1" stamp at the factory)
H = 1950 Flint, Michigan engine plant
B = 3100
A = regular transmission (3 speed) and clutch
943391-1000 = 942,391st engine out of that plant that year.
http://www.1954advance-design.com/chev-specs/1950-Chevrolet-t-ser.pdf
Check your paper title for the serial number used. Prior to the mid 1950's it was common for the DMV to use the engine serial number on the paper title. If that's the case, don't scrap your engine until you contact your local DMV to get a new serial number assigned.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Ex Hall Monitor
Ex Hall Monitor
The capital letter "I" was used as the number 1 on my '38. I think is was common practice at that time since I've seen others done the same way.
