| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 33 | I wanted to ask if you guys think the column shift arm for my '53 3100 is original and correct. Please check out the video I made in this and let me know. Thanks! Column Shifter '53 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From what can be seen, it looks original, and, well worn at the joints. | | | | | Joined: Apr 2016 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 33 | Thanks for the feedback. Is there something I do to help with the worn joints? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Worn joints. It all depends on how much slop there is, how well it shifts. If there is slop or sticking, you will probably have rotational shaft "bushing" wear and you will have pivot point wear. Some of it may be pot metal (hard to add metal to fix, hard to weld) and some will be rods/levers that may have wallowed out/elongated holes. These holes can be welded and redrilled, bushings replaced and the worn rods replaced/welded. There may be shafts to re-new also. There are a number of mechanical features involved all the way to the tranny levers. A little wear in each can add up to substantial lost movement or wiggleization. Observation will tell you what to do. I don't know if there are any bearings or not. If there are, that's another fix point.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | You know, as far as originality is concerned, that domed top to the shifter looks different from the one on my '49. I agree with bartamos in that each 'slop' of every joint is an addition problem, the whole is equal to the sum of all the slops. I replaced the rods with one's I fashioned myself using heim joints that attach to the shifter arms at the transmission. I have very positive shifts and ended up decreasing the throw which makes driving the 3 on the tree very pleasurable.
By fashioning my own rods I did away with the 'bell crank' pivot on the side of the bell housing. In doing so I eliminated three points of slop.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Looks like either a shift arm from a car or a Task Force. Knowing how GM didn't change much in mechanical design over many years as a general rule, I doubt that your shift arm is an issue.
