| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | I recently found a nos grill support for my 59 chevy. It did not come with the splash pan typically riveted to the support. How do I attach a new splash pan? Do they make those small rivets? Thanks, Brian M | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | by "splash pan" do you mean the piece right behind the bumper? and by "grill support" do you mean the panel behind the grill that it attaches to? those 2 pieces are bolted together on the trucks I've seen ... the only thing riveted up there is the bracket pieces that are attached to the back of the grill pictures would help Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only place that the splash pan was riveted on mine was at the ends where it attached to the fender.
Bill Burmeister | | |
