2 members (KEVINSKI, crenwelge),
108
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | It's the time of year when I always think of this. Is there any replacement heater motor squirrel-cage fan that will push more air in my '48?
It blows OK on the floor but when switched to defroster mode, it's not so hot.
Thanks! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | Wally, I refurbished my Harrison heater and blower motor based on a process outlined by Deve and I'm quite satisfied with the results. The heater has a 12V blower motor and a DC motor contoller with a potentiometer that gives me infinite fan speed control as opposed to high/low. Here's a link or two for your reading pleasure: Heater Restore12V UpgradeLet me know if you have any questions, good luck! | | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | Keep in mind that on the defroster setting it has to blow through the hoses up to the vents. If the hoses aren't in great condition the warm air escapes through the cracks and holes, or stops if they're kinked. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Also, the trim strip around your front windows should have a small piece of rubber on the inside, on each side of the defrost register, to keep the defrost air from escaping sideways along the window trim.... these little chunks of rubber keep all the air directed onto the window...
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | What temp thermostat you using? A 160 or 180 may not cut it in Montana. Maybe switch to a 195 over winter. Another trick I have used in a vehicle where the heater just could not quite do the job is to cover the radiator with cardboard. You will notice that semi trucks cover their radiators during winter . You do have to be very observant when you are driving during a warm snap so as to not overheat the engine. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Wally, me old Stovebolt taint as fancy as yours, still the same old original 216 with the same old 6v electrical system. I did rebuild the heater motor when I restored the original deluxe heater, i.e., turned the commutator, new brushes and bushings. Fan runs fine, will blow papers or rags around the floor in front of the duct, the defrost hoses are new and tight, and I had the defrost funnels out and reinstalled, (correctly). Been running a 180° stat year round for 12 years now. The Engine stays cool in the summer heat and plenty of heat in the winter cold. Once she's warmed up I can drive without a coat or gloves and that's saying something for an old dude like me with poor circulation in his mitts. I drive her regularly in the cold weather, as long as there isn't snow, slush or rain for the day. When switching over to the defrosters the air can barely be felt at the windshield. I've always felt there should be more air but short of redesigning the blower for more output, I think that's the way they were from the factory beck in the day. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Too much air to the windshield may not be a good thing under certain weather conditions. We have a lot of humidity around here. Defrosting and defogging are two very dissimilar circumstances. I have a motor which can be wired for really fast or not so fast. When I first set it up, I had it wired for really fast. On a humid, rainy day, that fast blowing fan may as well have blown a constant spray of water on the inside of the windshield (even at the low speed setting of the Harrison toggle switch). I rewired it for the slower speed and had much less trouble with the a wet windshield. Just like so many other mechanisms on these old trucks, the engineers always seem to do things for very real purposes. Carl
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Thanks for the link to the 12v motor upgrade. Added to the list! | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Little off the beaten path here but what a great bunch of old 40's and 50's pictures of general motors trucks with those 6 cylinders. Ill bet there has been Mulie or two on the back of that there 48'.? Great scrap book.. | | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | Love the history Wally! Reminds of when I hand drilled a new hole in the head of a SBC for a new alternator bolt. All done in the backwoods of a New York forest with a bolt found in my emergency Tupperware bin in the trunk of my 54 Chevy 4-dr sedan. I wish I had more photos to document it all like you did.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | |
