3 members (Gray_Ghost, Steelonsteel, Gdads51), 46 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
Hey guys,
I have been pulling some late nights on my truck, the other day I noticed that the headlights would randomly turn off and then on again with no real pattern. When they are getting power the beam seems to be strong, but it will just randomly go on and off, obviously not ideal for driving at night. Anyone have anything like this before?
The dash lights stay on strong when this is happening, and I have a full battery. Does this seem like a ground issue? Also it is both headlights at the same time not just one side or the other. I believe when the headlights are out the tail lights stay lit , but not 100 on that.
Any ideas appreciated for troubleshooting. Love these old trucks!
Crusing in the Passing Lane
Since you live in the rust belt, disassemble and clean all wire and switch terminals. Reassemble with some dielectric grease.
Ed
Be sure to clean the contacts on the floor mounted dimmer switch!🛠
Good idea guys, I think cleaning the terminals is my first line of duty. Hopefully that will be the culprit.
I had something similar in my 69 mustang that ended up being the switch. I found that turning the headlights off then back on always worked.
Good luck.
1956 Chevy 3200, 235 w/3 speed
Big Bolt Forum Moderator
if just the headlights are affected, and not tail or instrument lights, as Martin said, check the dimmer switch. Next I would check the headlight switch although, instead of a circuit breaker, there was a short fuse in the switch
(as seen here https://www.americanclassic.com/1955-59-Headlamp-Switch/productinfo/53%2D112/ ).
I am not sure if the fuse affects all lights or just headlights. Normally, a fuse would just quit working, but I would check it out anyway.
Mike
I had a similar occurrence on my '59. The head lights on one side would tune off at random times. The culprit was a loose fitting connector behind the headlight bucket; it would vibrate loose just enough to interrupt the circuit. Hope this helps.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
If both headlights are going out and coming back on but all the others are working, as already suggested check the dimmer switch. If you are using halogen bulbs then you might want to consider installing relays to the bulbs to take the load off the dimmer switch and headlight switch.
