1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | I have to believe this has been asked.........I have a 261 to be installed in a 1947 AD 3800. Has anyone had success in drifting the engine and transmission into the frame bolted together? Front inner and fenders are off. Something tells me I may run into a clearance problem. Cab is bolted to frame. Thanks - Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy amtrakjoe, if I am remembering correctly the transmission will not fit over the crossmember from the front of the truck, so I'm afraid it will have to be installed after the engine is in place, hope that helps. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The engine/trans assembly might fit if the top cover of the trans is removed. It would probably be simpler to use an engine hoist through a door opening or a long 4X4 post across the window sills and a come-along to lift the trans into place after the bellhousing motor mounts are in place. Jerry
| | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | Thanks guys - great idea accessing through the doors. I'm using a fork truck with fork extensions. I can butt them against each other and pick up Mr. 420 and set it right in place.
I tend to think long and hard working alone. I've trained the dog to dial 911 - Off we go.
Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 420's are light enough be picked up with the gearshift lever, or, with the top cover removed, with a suitable harness, if one is sitting in the seat. Leave it in high gear to get the clutch splines engaged
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Use two headless bolts (alignment "guide pins") screwed into the clutch housing to assure a "straight-in" installation of the SM420.
| | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | Joey, I tried, it doesn't work! Jim | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you have a buddy pushing behind the trans. while turning the trans. output shaft, it helps. Did you insert a spare input shaft or a fake plastic one from parts store before you tried the trans? That can help resolve issues with the trans. one cannot see.
After doing this exercise a dozen or do times, it will become second nature.
Ed
| | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | Ed......a dozen or more times.......Looks like I will guilt someone into pushing while I line it all up. I already aligned the clutch with a plastic "fake input shaft". I should be good. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | they drop right in if you have the cab off | | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | Yes I know about the cab. But my schedule didnt work out that way......but look at it this way - 4 bolts on the cab, 4 bolts on the SM420. The transmission is easier !!!! 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Engine hoist thru passenger door does wonders. I slid my sm420 under the truck, hooked the chains up to it and then the engine hoist. Raise and insert.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The shop manual (as I read it) said to pull the engine with the transmission attached so that's what I did. Not a good idea. Pulling Engine/Tranny. This was only made possible because the radiator frame had been cut (a 2nd time, actually) and not rewelded. I could remove the radiator and frame. That was commonly done in the old days I was told by an old-time mechanic. Radiator Support Cuts.I installed the engine alone. For the transmission I use a neat lift which had pitch/yaw/roll adjustments. Piece of cake. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | So - the engine went in fine. But - I forgot the throwout bearing. The transmission went in fine.......again. Almost forgot the clutch fork, but I have read that can go in later, but its horribly difficult. all bolted up front to back. I should start it some time this week.
1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Congrats on making progress! So, what method did you use to get the trans in? Mike B  | | | | | Joined: Nov 2012 Posts: 442 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 442 | Mike - I set the transmission on a floor jack. We jacked it level and slid it forward. Lesson learned - had to put in gear - no problem, shifter was 2 feet away. Its up and in. shifter fork installed as well. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | |
