8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | My next goal on my truck is to get the brakes working. It’s a ‘47 Chevy 2 ton. The back driver side wheels are locked. They were spinning free when I brought the truck home. No brake fluid so I filled and bled the brake system. Found the leak and am in the process of getting it corrected. Since then the back wheel locked. I can’t spin it by hand when jacked up. I can start the truck and move it so it will turn but there’s a lot of drag. Before I jump in was just looking for some basic ideas. Thanks for any suggestions. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Congrats on your 2-ton.
Not sure how long your truck was sitting, but if it still has the original single circuit brake system (which it sounds like it does), I would be very thorough going through the brakes. No fluid in the master could mean damaged/dried seals in wheel cylinders. A stuck cylinder could mean contamination/corrosion. I'd pull every wheel, then pull every wheel cylinder for disassembly & inspection, and then do the same to the master cylinder.
I always like to make sure a vehicle will reliably stop, before I make it go....
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Thanks for the help. The mc is definitely leaking. I didn’t see any brake fluid on the wheel cylinders but I figured that would be a good start. When I originally put fluid in it I drove around the field for a while. Brakes did good but I never got over 20 mph. | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | It sounds like you've got a corroded wheel cylinder on the wheel that's locking. The pistons probably can't retract fully, which is holding the shoes tight against the drum. Massage the drum a little with a dead blow mallet to drive the shoes back and slip the drum off to inspect the wheel cylinder. If it's stuck, I'd strongly consider replacing it rather than rebuilding. Good brakes are cheap life insurance- - - -for you, and the rest of us who share the road with you! Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would add to take great care with those drums. They are extremely hard to replace because they haven't been made in a long time. | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | My truck sat at a buddy's place for 2 years and when I went to take it home, the RF wheel was locked up. It skidded all the way on to the trailer and broke loose at the last minute. I was able to roll it back off the trailer (well carefully winched it off) and the wheel rolled OK, but with a tight spot. When I got to pulling the drum off, I found that it was an accumulation of rust that was dragging the shoes into engagement. For now, I pulled the adjuster off, put it in the vice to brake it loose (couldn't do it on the truck even with the adjuster exposed) and backed it off all the way. I suspect the wheel cylinder was locked up also, as Jerry suggested, as the system has been open for those two years (I managed to cut a brake line when I removed the bed - OOPS). The truck is getting a complete brake job before it hits the road.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One easy way to pull a vehicle with locked wheel is to put snow or water on the bed for it to slide on, yes, oil or grease would work too, kind of messy. Pieces of small pipe or rods placed under a piece of lumber would also work.
Ed
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Wreckers use a far piece of plastic with a wedge at one end, that they shove under the front edge of the tire- they start to pull on the car and the tire rides up onto the plastic and it acts like a little ski on the concrete. Only for getting it onto a flatbed, though. Works great
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Thanks for the suggestions guys, but it's a done deal. The gravel pad didn't present much resistance (the tire was half flat as well, so maybe provided a better "skid plate"), and the ramp and trailer track were fairly smooth. I aired up the tire coming off, which put a bit more torque (larger rolling radius) on the drum so it did roll off OK. We needed the arm workout on the come-along as well, so all good.
