4 members (TUTS 59, Lightholder's Dad, klhansen, 1 invisible), 165 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
#1244900 11/28/2017 3:18 AM
V
V Offline
I've got a stock 49 3100 that runs good but needs body work. Just got a line on a 49 GMC 1/2 ton w/blown engine but good body metal.
I can see via pics that the hood, grill and front fenders are different, question is, is the GMC cab and bed a directly fit to the Chevy frame and front clip?
I've also got a rebuilt 235 sitting in my shop, will it bolt up in the GMC?
" . . . is the GMC cab and bed a directly fit to the Chevy frame and front clip?"
Yes (the tail gate might confuse people?).
"I've also got a rebuilt 235 sitting in my shop, will it bolt up in the GMC?"
Yes, but it is shorter than the GMC sixes - it will sit further back from the radiator.
But, you referred-to using the Chevy frame?
Y
Y Offline
The front crossmember where the engine and radiator supports mount are different on the frames. You would need to drill out all the rivets in the front crossmembers and swap them in order to put the 235 into the GMC frame. You'll also need to use the Chevy radiator and radiator support to use the Chevy front sheetmetal. You'll see the difference once the engines and front sheetmetal are out.
Check out this link on the Carter website.
Crossmember difference
Credit to Rob English at oldgmctrucks.com
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
V
V Offline
Good info, thanks TIm,yellosub54.
I haven't seen the GMC yet, awaiting pics.
Fox Offline
In Canada, for some reason, all the little Bolt GMCs utilize Chevy cross members, rad supports and Chevy engines, but have different radiators and tops of the core support. It makes this discussed swap very simple. I was unaware until recently about the HUGE discrepancies between US gmc/Chev cross members. Best of luck.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I personally would not try to remove and swap the riveted on crossmember. It would be much easier to fab a plate on the GMC crossmember, relocating the engine mount holes rearward to fit the Chevrolet 235.
V
V Offline
Good info. Ends up the engine may not be blown and is a circa 1975 250 (or 230) with a quadrajet 4 bbl, dual exhaust and bolted to a turbo 400 auto with open driveshaft and late model rear. It is also slammed. Present owner bought it as is and would rather have a running Karmann Ghia......Trade is eminent..... I'll update in proper forums.
Frontend
pic 2
pic 3
