3 members (Jays58, Youngin' Tut 59, 39Master85), 91 guests, and 5 robots.
Topics128,095
Posts1,056,468
Members48,444
#1244333 11/23/2017 12:55 AM
An old fire truck is beginning to look like the 550 I drove over a half a century ago. I took the axles and the rest of the air brake stuff out of an old LCF parts truck. I mounted a Fontain 5th wheel of the era the way we did it back then. U-bolts and a 2x4 for a cushion. Not DOT legal any more, but I want it to be the way we did it. The fuel tanks are just dummies. 100 gallons of gas would get stale on me. I thought a pickup tank would fit behind the seat, but the larger original tank is several inches taller and the fill neck doesn't fit. The hole in the cab is higher than a pickup and I didn't want to deal with that. I mounted a spun aluminum tank behind the seat. I have to flop the seat forward to fill it, but that's OK.
https://photos.google.com/share/AF1...aWRyU1NYNnRCZ09OVElhckdEelNLbXNobjlnTnNn
The tubeless tires are coming off in favor of 10.00x20 tube required like I ran on my old GMC. I bought a trailer from Saunders Leasing in 1967 that had tubeless tires and I have been running tubeless ever since.
Big Bolt Forum Moderator
that is sweet! I should find some tanks like that for my 58!
Mike
I like the look of that truck. I hope you do not paint it. I have a 1960 Internatonal B140 all wheel drive that could be a tractor too.
1959 Apache 31
Moderator
Moderator
2 Offline
Another Missouri truck being saved!
Cool story and truck.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Looks good !!
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Crusing in the Passing Lane
Ken,
What engine and trans?
Ed
So, when are you going to plow the Lower 40 with it?
It is a 324 Olds with a New Process 540. My original 550 had a 370. I have a wrecker and a winch truck with a 370 but I am not going to swap them. You can't tell the difference between a 324 and a 370 by looking at them. All 3 of them have 2 speed Eatons.
I'm accumulating the bits and pieces to make a "tractor" also- - - -a modern day version of a doodlebug. I'll be using a Mercruiser Marine 4 cylinder engine, a SM 318 3 speed trans, a 1946 truck crash box 4 speed, and a vacuum shift 2 speed rear end with dual wheels. I'll be using a narrowed pickup truck straight axle up front. If I've done my math right, that works out to 32 forward speeds and at least 16 (?) in reverse!
Moderator
Moderator
2 Offline
I get 24 forward and 8 reverse in my math.
Foreword, 3 x 4 = 12, 12 x 2= 24
Reverse, 1 x 4 = 4, 4 x2 = 8
Are you testing us?
Great projects for both of you.
Keep the pictures coming.
Don
"The Flag Pole"
1953 1-ton pickup
I almost got a fire truck with 370 and 540 like that, must have been a common combination.
Ed
How about reverse/reverse as a forward speed, with low/high rear axle options? That's usually the lowest speed of the creeper gears on a doodlebug. There's also a bunch of options with one trans in forward gears, and the other in reverse, plus low/high rear axle choices. There's a lot of ratio overlaps, however..
