5 members (Gray_Ghost, GMCJammer51, Otto Skorzeny, Paul Mullen, Jon G), 172 guests, and 5 robots.
Topics128,078
Posts1,056,046
Members48,433
As the wiring project is snailing slowly along I thought it was time to start removing old bits from the truck for cleanup & testing. I have a new 12v light switch but will need to use the old knob and fixings. I couldn't see any way to get it out. I expected some sort of hex nut or maybe some fittings for GM Special Tool #007 but saw nothing that looked promising. How can I get it out without wrecking anything?
The ignition switch was also being mysterious. How does it come out?
I checked the Chevy shop manual but it did not cover anything as basic as this. I can guess that trained mechanics already knew such elementary info . . .
Vintage Paul
Paul O'Neil, SoCal
1951 Chevy 3600 Project
shop manual section 12 page 36/37 .... there's a button on top the light sw that when depressed allows the knob w/ shaft to pull out, then there's a bezel-keeper nut that holds the sw in .... ignition sw also has a bezel nut that usually takes some struggle to get loose if you don't have the correct tool .... the light sw doesn't care if you use 6 or 12V
Thanks Bill, I will look that section of the manual over and see if I can get the switches out for cleanup.
What holds the cigar lighter in? I have a USB adapter that uses the cigar lighter for power if I can get it wired up correctly.
Vintage Paul
Paul O'Neil, SoCal
The cigar lighter has a long sheath that unscrews from the main body from the backside.🛠
