8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible),
181
Mod | | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2017 Posts: 42 | As the wiring project is snailing slowly along I thought it was time to start removing old bits from the truck for cleanup & testing. I have a new 12v light switch but will need to use the old knob and fixings. I couldn't see any way to get it out. I expected some sort of hex nut or maybe some fittings for GM Special Tool #007 but saw nothing that looked promising. How can I get it out without wrecking anything?
The ignition switch was also being mysterious. How does it come out?
I checked the Chevy shop manual but it did not cover anything as basic as this. I can guess that trained mechanics already knew such elementary info . . .
Vintage Paul Paul O'Neil, SoCal 1951 Chevy 3600 Project
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | shop manual section 12 page 36/37 .... there's a button on top the light sw that when depressed allows the knob w/ shaft to pull out, then there's a bezel-keeper nut that holds the sw in .... ignition sw also has a bezel nut that usually takes some struggle to get loose if you don't have the correct tool .... the light sw doesn't care if you use 6 or 12V
| | | | | Joined: Oct 2017 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2017 Posts: 42 | Thanks Bill, I will look that section of the manual over and see if I can get the switches out for cleanup.
What holds the cigar lighter in? I have a USB adapter that uses the cigar lighter for power if I can get it wired up correctly.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The cigar lighter has a long sheath that unscrews from the main body from the backside.ðŸ›
