5 members (Gray_Ghost, frogfarmer, Otto Skorzeny, jay d, 50Chevy3100), 52 guests, and 3 robots.
Topics128,056
Posts1,055,804
#1244168 11/21/2017 7:57 PM
I'm trying to remove the speedo instrument cluster from my 1956- 3100.I've removed the 3 screws and pulled it forward about half an inch then it stops as if its hitting somthing and wont come forward any more.Do I have to use brute force or is there something else I have to take off.
likely need to remove the rigid oil pressure tube .... then need to weasel things around a bit [gently, wiring is tight] they can catch on the edge of the opening
We assume you disconnected the speedo cable?
Craig
Moderated by  ndkid275, Phak1
