6 members (Paul_WNC, Gdads51, Shardean, Greg_H, NorCal52Suburban, Waveski), 60 guests, and 6 robots.
Topics128,021
Posts1,055,357
Members48,420
#1243512 11/16/2017 2:28 PM
I've removed all the rotten wood and rusty bed strips from the bed.The angled ones were spot welded to the side of the bed.Whats the best way to attach new ones as I dont have a spot welder? The strips are stainless steel aswel nice and shiney
Stooby #1243517 11/16/2017 3:19 PM
I think some people have reported that they bolted them on?
I am not a welder, but I also think that some people have posted that they have "plug" welded them on and then ground the weld-points flat.
I made the mistake of buying stainless steel side angle strips. It will be interesting finding someone to try plug welding them together (bolting them on might be the only answer?).
Maybe a welder will post information and clear-up/correct the speculation about possible options?
Stooby #1243567 11/16/2017 10:25 PM
Insomniac
Insomniac
I plug welded the angle strips to the bed sides. However, I did not use stainless angles. I used 1" x 1" angle iron instead. Personally, I wouldn't weld the stainless ones on - I'd bolt them. Two of the fender bolts go through the angles anyway. Picture attached..
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Stooby #1243568 11/16/2017 10:29 PM
Thanks, Gord
If you were going to bolt them on, would you have the nuts sticking out inside the bed, or outside the bed? Or, does that not matter, because they would be below the bed wood?
Stooby #1243589 11/17/2017 12:08 AM
Insomniac
Insomniac
If I was bolting the angle strips to the bed sides, I would use button head bolts with the nuts outside the bed. Locate the first bolt so the nut is inside the stake pocket. You should be able to reach the nut from the bottom of the pocket. The rest of the bolts would be located so the nuts are inside the fenders.
Just for fun, here's a before photo:
Gord 🇨🇦
Stooby #1243656 11/17/2017 3:07 PM
Since the fender bolts were/are clutch-head, I'll use the same SS clutch-head screws/bolts in the orientation suggested by Gord. I might have to grind a little off the threaded ends of those screws/bolts?
clutch head rear-fender bolts -
by the piece
Full SS bed bolt kit for $40 unpolished ($70 polished)
Stooby #1244295 11/22/2017 7:50 PM
you could use rivits
Stooby #1244299 11/22/2017 8:22 PM
Or, use stainless button head bolts on the inside of the bed through the angle strip (as suggested by Gord), which is what I am doing, and use stainless acorn (cap) nuts on the outside of the bed. In fact, I'm using a lot of s/s acorn nuts on any exposed bolts on the truck ...tailgate brackets, rear light brackets, spare tire mount, etc. Gives it that finished look.
Mike
Mike
1951 3100 5 window
