4 members (Wayne67vert, Gray_Ghost, BC59, 1 invisible), 155 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
Moderated
Moderated
I have a 1951 3100 Deluxe with original SM420 and closed drive shaft. I have a matched set of driven gear and pinion to install to get the speedometer to work. Anyone have pictures, directions or tips. I know I need to pull the u joint yoke to replace the pinion gear. Anything else worth replacing before reassembly. Thanks Justin
1951 3100 5-Window in Scottsdale, AZ
As I dimly recall, the "drive" gear goes around the forward yoke on the 4-speed's u-joint?
http://chevy.oldcarmanualproject.com/parts/1929_54/220a.htm
If that is the case, follow the instruction in the Shop Manual for transmission/u-joint removal. And, be sure to follow the instructions for gasket adjustment when replacing the u-joint bell/ball cover (universal joint ball adjustment).
The forward yoke for the 4-speed u-joint is held in place with a bolt (and heavy washer) through the middle of the yoke.
"As I dimly recall, the "drive" gear goes around the forward yoke on the 4-speed's u-joint?"
You would be correct. 4 speed tranny Cross section pic
It looks like drive gear is on the output shaft, but if you blow up the picture, the drive gear is really on the tail end of the Forward yoke.
I believe the speed-O drive gear is pressed on.
Don't forget U-Joint Bolt Lock Clips
Q. Anything else worth replacing before reassembly .
Check for play in propeller shaft, wiggle it up down side to side.
If it moves, the propeller shaft bushing & oil seal are bad.
A quick fix is to install a Okie bushing sleeve.
The Okie bushing sleeve has the rear yoke bushing and the propeller shaft bushing & oil seal inside a sleeve.
1951 truck bushings are press fit, you will need a bushing puller to pull the front bushing out.
Then slide in the Okie bushing. You leave the existing propeller shaft bushing and oil seal in the torque tube.
(Check pictures below) .
At the rear of the U-joint ball housing there is a screw on retainer cap.
Inside the cap there is a oil seal sandwiched between two steel O-ring washers.
The oil seal dries out and it looses its tension which keeps the retainer cap from unscrewing itself and sealing.
Some oil seals are cork some are rubber. Replace with a Rubber oil seal and dress it with a thin film of grease before installing. The threads should be clean and dry.
To insure the rubber oil seal doesn't get cut-up, polish-up the front end of the torque tube with some emery cloth so it has a smooth surface to slide on. Do the same with the ball portion of U-joint ball housing. You want the ball collar cork oil seal to have a smooth surface to slide on. Lubricate cork oil seal with graphite grease before assembly.
Picture lower right corner of page
(Also Check pictures below)
The four Universal Joint Ball (Housing) collar bolts, 8-12 ft. lbs. Torque.
The four Universal Joint bolts or cap screws, 25-30 ft.lbs. Torque
The one Universal Joint forward yoke attaching bolt, 15-20 ft. lbs. Torque
xfiles
You are an ace, jorb
Isn't it nice being able to post photos?
Tim
Thanks for the approval !
I had to correct the last attached pic Looks better now.
Yes, it is nice to be able to post photos.
Would be nice to be able to insert attached photo link into the reply box along with the text.
Current set-up will suffice.
Just curious do you have to pick-up leafs at your new location. brrrrr
I have only a few deciduous trees and they have small leaves (and a flat lot/neighborhood). I just mulch-mow them.
In NY, I used to mow leaves with a three-bagger on my lawn mower.
Moderated
Moderated
Jorb and Tim - Thank you for the help and the pics!
