I have purchased the white "CHEVROLET" letters for the tailgate of my truck. Any tips on how to get them lined up properly the first time? The tailgate has the raised letters. Thanks
Jim
1955 Chevy series 2 6 cylinder, 3 on the tree Short bed, step side
I think Tim might be getting at this: some years were body color, some not. Are you a purist or a " I just like it that way?"
A trick I used on the rigs to attach squarely VERY sticky warning signs was get a bit of slightly diluted windex, spray on the wall, line up the sticker perfectly and lightly "squeegee" the sign smooth. The windex allowed you to be able to move it a bit before "commiting" to its final position. Worked like a charm.
1970 Chevrolet C10 Grandpa's -- My first truck -- In progress to shiny Follow the build in the Project Journal 1950 Chevrolet 1-Ton Dually "Ole Red Girl" In the Stovebolt Gallery More pictures here 1951 GMC 9430 1 ton dually--Shiny! | 1972 Chevrolet C20- Rusty- the puzzle box lid for the C10 | 1962 AMC Rambler American- my wife's Parts trucks- 1951 GMC 9300 | 1951-GMC 9430 | 1951- Chevrolet 1300
It's the '55 that's in my signature. I'm assuming the factory originals were painted on. Yes, it would be interesting to know how they did it.
I'm not a purist and not at all knowledgeable in the specifics of various years. I just like the look. Mine are painted body color. The truck had a resto on it many years ago. Not sure who did it, but they cut a lot of corners. Based on that I assumed they just sprayed the tailgate as a quick and cheap option rather than try to preserve the lettering. This year may have had body color for the letters. I'll have to check that out. Maybe that's what Tim was getting at. I think the Windex thing could work. Takes a lot of pressure off trying to get it perfect on contact.
It's a definite learning experience.
Jim
1956 Stepside tailgate attached below (no painted letters) 1958/59 Fleetside attached below (painted letters) - 1958 "model change" year (stated in ads) 1960 Stepside (painted letters) - 1960 "model change" year (stated in ads) 1959 Stepside (painted letters)
Questions about possible painted letters: - bedside vs fleetside (which had no "CHEVROLET" on the tailgate in some years)? - with RPO chrome bumpers (front & rear)?
Nonetheless, it is your truck. Of course, paint the letters as suits you.
Before doing "research" on a question, it is nice to be sure that the truck series/year in question is the one in the signature. It often is not.
Tim, You are absolutely correct. Thank you for the info and pics. Very helpful. My truck is a dark green (Juniper I think) I think the white letters will be a nice contrast. I've got whitewalls and trim rings on it which you wouldn't see that on a work truck back in the day.
I'll use the water Windex laying the letters. Ill show you what it looks like. Thanks all Jim
Jim
We put the decals on after painting but before clear coating. First spray a couple coats of clear around the letters but not on them and then spray across the entire surface with a couple coats. Once dry the area is color sanded more on top of the letters till they are level with the area around them. This gives a "no bump" feel when fingers are runs across the letters and being buried in clear they never fade or curl at the edges.
That's very clever! Apparently the clearcoat doesn't lift the adhesive on the decals?
Vehicle sign shops have lots of experience installing vinyl graphics. No doubt they could install your lettering perfectly straight.
