| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I sandblasted all of my panels on my 56 chevy. When I was done I put an etching primer on them because I knew it would be a long time before I got back to them to do the body work and I didn't want them to rust anymore. My question is can I put body filler right over the etching primer? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | That is correct, however make sure the surface primer has enough bite for the filler to adhere to. Good luck with your project.
Tony | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Be sure to store your rig indoors. The etch primer is porous and needs the final coat of 2k primer to be bullet proof.
Stuart | | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | Tony When you say make sure it has enough bite do you mean rough up the primer with red 3-m pad or light sand paper? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Kevin:
Yes, that is correct, per the experts. I am restating what I have been told. Good luck.
Tony | | | | | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | Thanks for the help.
Kevin | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | kevint, If you coat with etch primer, then sand through the primer (accidentally) when roughing for bondo, you are back to square one with no bare metal protection. I don't think you are suppose to apply etch primer OVER bondo. If you etch prime, then coat with a 2k primer, your finish is solid, and you merely rough the 2k a tad for bondo...no sand through problems. You can then spot coat over your bondo with 2k again. This is how I understand it. Stuart | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I was told in one post to never put filler over etching primer. They tell me it will not stick. I understand it is best to put down a layer of etching primer, then 2k primer, then the filler. here is the post: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=003984;p=1#000005
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Michael1964,
Good point! I did some additional reading on this topic, and it looks like you are right. I have been putting filler over etch primer, and all seems well, but I just might start coating the etch primer with 2k primer, and finish with filler over that.
Stuart | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I worked as a heavy collision tech for several years and used my fair share of plastic fillers.I never put filler over primer, paint or anything other than bare metal. If you stop to think about it, plastic filler is only as strong as what it is bonded to. I have seen panels sustain collision damage that were repaired previously with filler bonded to metal, and the filler didn't even crack. I have seen panels with filler over paint get hit and the filler breaks or falls off the panel.I know body men who have done it both ways, but that is my experience with body filler.( my 2 cents worth) 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | I dont know of any paint manufactor that suggests you apply filler over etch primer. In fact the beroxide in the filler's hardner can react with the etch primer causing the filler to lose adhesion.
Another thing is that sandblasted metal might have more tooth then what the etch primer can fill. Meaning even after you spray your etch primer you can have some spots of bare metal exposed because the etch primer can not fill that tooth left from the sand. Most manufactors want alteast 180 grit prior to etch primer.
Personally I would scuff that etch primer with a red scuff and apply two good coats of epoxy primer over that etch. Epoxy has far better adhesion and corrosion protection then etch primer. Plus epoxy primer is NOT PORUS like that etch primer. Etch primer can absorb moisture throu it, epoxy primer will not. Plus you can apply filler over epoxy primer with NO PROBLEMS. Many car manufactors like Mecerdes Benz, Lexus and Madza recommend filler to be applied over epoxy primer.
An epoxy primer that would work with that etch primer would be PPG's DPLF line. But before you buy any epoxy make sure it can be applied over an etch primer as some can not, but DPLF can...Eric | | | | | | Anonymous Unregistered | | Anonymous Unregistered | sevt_chevelle is correct epoxy is the only type of primer that you should use filler over. Most of them recommend the epoxy dry 24 hrs. before appling filler, also I scuff it before putting filler or primer over it if it has been on more than 3 or 4 days. | | |
