2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | 1950 216 very much all original. 6 volt gmc. Canadian. The truck idles and runs fine once started. When cold starting the truck at room temperature it is hard to start. What it does: step on the floor starter it turns over nicely but will not fire until I pump the gas peddle repededly. Now it fires but will have fuel running down the outside of the carb. I can either leave it idle or nurse it up to a faster rpm until the excess fuel is used up. At that point it runs fine. Not flooding at this point. Now if I turn the ignition off . I can restart it with just a touch of the foot starter and no throttle needed. How do I get her to start with out flooding at first start up? Thanks | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | All cold engines need to be choked. Doing a Jose' Greco flamenco dance on the gas pedal is not a substitute for pulling the choke all the way out, cranking until the engine fires, and releasing the choke about halfway to let the engine warm up without stalling. Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Guilty as charged on the Flamenco action. I know many of you or working the choke with your right hand, stomp starter with your right foot and full on flamenco with your left foot. I need to find a much more cool way to start a cold truck when I train my boys on the steps. The restart after warm up is much cooler, turns over once and fires right up.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | That I can try. But seems like a shame cause I'm such a darn good dancer. Lol. Thanks. Next question is why does it start so easily the second time. Even if it was only running 30 seconds on the initial start up . The engine would still be cold but the fuel obviously would be at the carb. Thanks | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | The choke is where the magic is. I start my truck the same way every morning whether it's 80° or 20° below. I turn the key on, pull the choke out, and hit the starter. It starts right up, maybe two revolutions on the coldest days, and I NEVER touch the gas. | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | A crappy replacement choke cable was mounted to the bottom lip of the dash when I bought mine from the previous owner. He showed me the starting process- one or two pumps of the gas, pull the choke, foot start... Problem was the crappy choke cable wouldn't pull out all the way, and it was getting worse as time went on, so the pumping the gas was necessary, but not reliable.
Best thing I did was buy/install a brand new original style choke cable mounted in the stock location (so it's easier to operate than the other one was). Truck starts just like twotone describes. I occasionally have momentary trouble starting it when it's already warm and I've over-choked it when I shouldn't have. | | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | Thanks interesting. I've been experimenting starting it a few different ways lately. I have noticed full choke turn it over a bit then a couple pumps and she starts. Now I'm think I may need to check my choke cable . I may not be getting full on choke. | | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | Update... well I was snooping around my carb and found that the choke spring was not hooked on the tab. So when I had the cable pulled out all the way the choke would barely move. So I hooked it as it should be. Now I pull the choke step on the starter and I can't even get my foot off the start button fast enough before it starts. And as stated in the above posts reduce the choke to half and let it warm up. It is absolutely amazing how fast it starts. Thanks for all the help guys . This fix makes this truck just that much cooler and the only dance I will be doing is the happy dance from here on in. Thanks again | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Congratulations
Thank for posting your progress/resolution report. | | |
