4 members (lumbersawyer, Hush, 2 invisible), 64 guests, and 3 robots.
Topics128,026
Posts1,055,407
Members48,422
#1241722 11/02/2017 8:49 PM
I have recently run up a 235 chevrolet engine the Number starts with KEA. I have oil getting in the water, some one said it may be an oil pipe through the water jacket, doe any body have any other ideas.
Thank Howard
Howardwade #1241761 11/03/2017 1:33 AM
If it is a '52 engine, it will have a copper pipe running through the block. Remove each end of the copper pipe, plug one end and put a Mity-vac on the other to see if it holds a vacuum.
You will need to remove the valve cover to remove one end from the rocker shaft fitting, and remove the other end from the oil distributor on the driver's side of the block.
Carl
Howardwade #1241765 11/03/2017 1:52 AM
KEA = 1952 235 6000 series truck
