0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I just had new kingpin bushings installed and reamed at a local machine shop. Nice job with just a push fit on the pin. I have a 3/4 ton 54 chevy. In the kit comes the bottom bearing consisting of 5 pieces. I have not found what the upper clearance should be in relation to the axel. The shop manual doesn't show a shim there. I have .013" on the pass. side and .018" on the drivers side. All the weight is carried on the lower bearing so do you need a shim on top? Id like to assemble the truck this weekend but if I need to order kingpin shims I guess its up to you alls answers. Thanks Sharon | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sharon, Grigg is a good source of information. Here is a write-up by Grigg."6.5 test fit your spindle and the thrust bearing over the axle, fit any shims necessary to take up the gap on the top side of the axle. Don't pound and wedge it together but also don't leave any gap a shim will fit in. (in my case no shims were necessary but before it would fit together nice and snug I had to remove the burs and wear ridges as previously mentioned.)" Here is an excellent "Tech Tip" on king pin replacement, by Randy Baumann.
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** I think most shoot for a clearance of .005 or less. ** | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Very nice article. I will find a shim kit and take up all the slack. Thanks Tim | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | That was the one I was going to order, thanks Tim | | |
