6 members (Cletus1950, Otto Skorzeny, Shade Baby, tclederman, Hotrod Lincoln, GIJOE298), 127 guests, and 3 robots.
Topics128,148
Posts1,056,809
Members48,454
How do you all recommend sealing the sheet metal joint between the lower and upper rear cab panel on a '53 short bed? Seam sealer, lead, or something else?
Thanks in advance.
From the Factory Assembly Manual Section 14 Sheet 9.00
3703155 Sealing Compound Apply to the entire length of the seam with a pressure flow gun using a nozzle orifice of approximately 1/16 inch and shaped to fit into joint so as to force the compound back as far as possible. The joint is then to be wiped so as to obtain a smooth fillet not more than 1/16 inch wide.
Definitely not lead.
We used the same sealing compound, after generously squeezing/squirting rust converter down into the cleaned-out seam.
3M panel adhesive is a 2 part epoxy type material which will securely seal this seam. Media blasting and epoxy primer prior to the application of this product will ensure that it will not bleed rust.
This product is very sandable once it has cured.
Carl
I think we used the moisture curing Urethane Sealer from 3M.
https://www.3m.com/3M/en_US/company...13+8710891+8711413+3293242000&rt=rud
Thanks everyone.
