| | | Forums66 Topics128,129 Posts1,056,361 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | Hi- Any thoughts on why my drivers window stops 1/2" short of top?? Do I need new regulator? Is there an adjustment? Note: window is not binding. Ron A | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | No adjustment that i know of. The track on the buttom of the window may have fallen out of the regulator rollers. Take panel off and slowly roll up window until you can see and feel the rollers in the track. 1 track is on door and another fastened to buttom of glass. Otherwise the regulator gear may be skipping a tooth or 2. Not hard to investigate without having to dismantle everything. Let me know what you see. I may have bits and pieces you could have. | | |
