2 members (jaycoop, Otto Skorzeny), 108 guests, and 1 robot.
Topics128,131
Posts1,056,367
Members48,441
#1240950 10/27/2017 1:07 PM
Well, how are all my fellow Bolters a doing? Not quite sure what is going on Ol 55, but she has a little ticking going on, its sounding like when you clamped down a poker card in the spoke of your bicycle. Not real bad now but it seems to click faster as you rev her up. I should just get off my beer drinking but and go check it out rather than simply ask you guys. Anyway need a little bailout here Bolters........... Thanks again
spark jumping from plug wires,Open the hood when it's dark outside, you will see it. Valves need to be set?
Tommy
59 apache 1/2t
261 short stepside
Well checked out the the plug wires ast night and no fireworks. I'm thinking it might be something broken in the upper end? Not quite sure?
Sir Searchalot
Sir Searchalot
Many times it's an exhaust leak. Use a broom stick to touch and listen all over and see if you can find the location. Exhaust leaks do increase with rev. The air pressure can make that noise. Hope it's that. Stick will pick up vibration noise and transmit from end of stick to other end near your ear. If you are a rich guy, buy a stethoscope. Stick not great at picking up exhaust noise, but good for process of elimination. Just be aware of manifold leaks. Tighten all exhaust bolts to see if it changes. Be sure to check the exhaust flapper also. (heat riser)
My tool kit includes an old cheap Stethoscope from Harbor Freight. Good for "isolating" truck noises.
Walgreen's Stethoscope
Cheaper from . . .
Here's one that has an attachment specifically for listening to engine noises.
Automotoive Stethoscope
Yes, just like the one I got from Harbor Freight.
Harbor Freight, $5.00, same as the Summit. Best $5.00 Ive spent in a while.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
