1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 7 | The interior doors and windshield window trim on my '50 1500 are either stainless or chrome ( I think stainless). In either case, it's not in great shape. So far I can only find Painted Door window trim and no windshield trim at all. I've checked all the vendors I know of. Was wondering if anyone has a source for these interior parts. | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | Tried to send a PM but unable to. Says you are over your private PM limit. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Over the limit because the limit is zero until a new member makes about 5 posts.
Reason (I think): a little insurance for loyal members that a new member is not a "hit-and-run" ("snatch and grab") buyer/seller.
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Ran across stainless interior window mouldings on Amazon, but DANG - $$$$$ Stainless Window Mouldings
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Interior or Exterior?
Didn't the "frame"/"moulding"/"molding" change in 1951? | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** I have the inside window trim for no vent window doors {Flawless Stainless Steel Highly Polished} but have been unable to contact R McAnulty. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Until he makes more posts, he is a personna unreachable.
