6 members (Steelonsteel, dt235sd, Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 65 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#1240628 10/25/2017 12:36 PM
My '57 Suburban has never had a jack since I have owned it. I carry a large bottle jack just in case, but I am wondering what kind of jack that truck had, and where it mounted. The chassis is pretty high for most jacks and thinking maybe an original (or original style) jack would be good to have?...
'57 Chevy Suburban; '70 Chevy Impala.
It looks like the 1957 3100-3600 standard jack was a bottle jack (?) with around 15" raised height.
The 3800 bottle jack (?) had around 16" raised height.
Really? And where did you put it, under the frame, are there specific spots? 15" does not seem like much!
I was thinking maybe a bumper-mount jack could work, something from a big sedan from the '60s to '80s... But then, it would take a lot of space to carry around...
I guess I will keep my bottle jack!
see FAM sect 14 sheet 16.00 .... same jack as P/U, stowed under the driver seat .... jack under the axles, not the frame, jacking under the frame means you hafta lift way higher to get the tire off the ground cuz of springs hanging, bumper jacks are iffy with the shape of the TF bumper, and same deal, need to lift too high
Thanks Bill! My Suburban has Camaro front clip and Corvette rear, all independent, so lifting under the axles does not work so good, but it sure would make sense! I guess I am on my own...
Thanks guys!
