| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | While extracting the pilot bearing I discovered this Expansion Plug in the back end of Crank. Is it covering a bearing ? The pilot bearing covers it . Bigger viewOn a 1960 235 engine with Hydra-Matic transmission.
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | When I see a plug like that I think it is a core plug for the cooling system. Though there is not enough of the engine in the picture to take a good guess, and I have not seen enough of the backs of these engines to know for sure. Though somebody that does will be here soon with the correct answer. Jeffrey | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | It is the back of the crank shaft. There is nothing but solid metal in that location. No oil passages in a Stovebolt. Could it be that it is not actually a plug and just a step machined in it. I don't know about H-Matics, (so@@y about the ab@eviations, but my key between "E" and "T" quit wo@king), but P-Glides have a diffe@ent sized hole in the back of the c@ank, needing a special pilot bea@ing. Ca@l (New keyboa@d will be in on the 26th.)
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Carl, it appears to be a Expansion Plug because it got scuffed when I drilled out the old pilot bearing and I can see a rim on the edge.. I also believed there was not anything behind the pilot bearing besides the hard crank steel.
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Mystery solved. It is the way the inside of the crank end was milled. They left a raised lip at the bottom of the hole. No plug, just steel. I guess the drill bit I used to drill out the pilot bushing was sharper then I thought to leave a scuff mark.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I just saw the first photo. It was too small for me to tell that is was the back end of the crankshaft. Eyes are getting old. Jeffrey | | |
