6 members (46 Texaco, Shade Baby, BarryP, Oswald, Robert Crandall, dt235sd), 92 guests, and 2 robots.
Topics128,162
Posts1,056,910
Members48,458
While extracting the pilot bearing I discovered this Expansion Plug in the back end of Crank. Is it covering a bearing ? The pilot bearing covers it . Bigger view
On a 1960 235 engine with Hydra-Matic transmission.
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
When I see a plug like that I think it is a core plug for the cooling
system. Though there is not enough of the engine in the picture
to take a good guess, and I have not seen enough of the backs
of these engines to know for sure. Though somebody that does
will be here soon with the correct answer. Jeffrey
It is the back of the crank shaft. There is nothing but solid metal in that location. No oil passages in a Stovebolt.
Could it be that it is not actually a plug and just a step machined in it.
I don't know about H-Matics, (so@@y about the ab@eviations, but my key between "E" and "T" quit wo@king), but P-Glides have a diffe@ent sized hole in the back of the c@ank, needing a special pilot bea@ing.
Ca@l
(New keyboa@d will be in on the 26th.)
Carl, it appears to be a Expansion Plug because it got scuffed when I drilled out the old pilot bearing and I can see a rim on the edge.. I also believed there was not anything behind the pilot bearing besides the hard crank steel.
Mystery solved. It is the way the inside of the crank end was milled. They left a raised lip at the bottom of the hole. No plug, just steel. I guess the drill bit I used to drill out the pilot bushing was sharper then I thought to leave a scuff mark.
I just saw the first photo. It was too small for me to tell that is was the back end
of the crankshaft. Eyes are getting old. Jeffrey
