3 members (Hotrod Lincoln, DadsFirstPickup, Otto Skorzeny), 137 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
"Surrounding" the in-cab hand brake lever is a small metal plate, approx 4-5" long and 1" wide. It can slide up and down the lever. Is this supposed to go above the floor pan, or below? How is it secured?
Bob
BobS46
I believe the plate you reference goes below the floor board. I have a foam piece i bought from one of the normal suppliers and that plate goes under the foam piece and holds the foam tightly to the floor board and creates a seal. You'll notice that piece isn't flat but has a bend that goes around (over) a bolt down there somewhere. I hope that helps. If need be, I can post a picture.
