7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 34 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#1239580 10/17/2017 1:38 AM
I submitted an earlier thread about replacing the stock 3-speed transmission in a '53 3100 because of interior damage done by a PO. After receiving lots of information and advice, I need to ask for more help. I have located a '54 3-speed and need information about the possibility of it bolting up to my truck without needing changes or alterations. I've been told the '54 will bolt up to the '53 bell housing and the bell joint on the torque tube just as the old trans did. If this is correct, part of my problem is solved. My main concern after the transmission fits the bell housing and bell joint is the shift linkage. Will the shift linkage on my '53 truck hook up to the shifters on the '54 transmission? I'm not sure my limited mechanical ability would enable me to fabricate new linkage arms. Help and information very much needed and appreciated.
'53 3100 Short Bed
Texas Peace Officer - supporter of the Badge and the Blue Line
Pain is part of life, Misery is an option.
Crusing in the Passing Lane
See if the shift arms on the replacement trans. are the same as the original ones.
Ed
If the 54 trans is from a car it will not bolt up to the truck bellhousing.
My Blog
Haven't purchased the replacement trans yet so it's still with owner. Shipping probably gonna be high so trying to be sure it will work before payment/shipping
'53 3100 Short Bed
Repl trans said to be from '54 1/2 ton
'53 3100 Short Bed
Another question after reading email more closely: the replacement trans could possibly be from a '54 3/4 ton. Owner is unsure if the trans came from a 1/2 ton or a 3/2 ton. One piece of information from another bolter stated that the replacement trans must be from a half ton only.
'53 3100 Short Bed
1/2 and 3/4 ton used the same 3 speed.
If from a truck the 54 trans will be a direct fit in your 53.
The 54 3/4 ton trans will have a open drive adapter on it, but that can just be removed.
My Blog
