3 members (Bill Hanlon, WICruiser, Gray_Ghost), 182 guests, and 0 robots.
Topics128,089
Posts1,056,143
Members48,436
I keep checking on my new brake lines and fittings and almost daily I notice small leaks that I have so far been successful in stopping. Should I Re-Bleed the brakes every time I fix one of these slow leaks?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Not unless you open the system up. If your just tightening the fittings each time you should be okay.🛠
I'm doing the tighten loosen tighten loosen tighten trick so I guess I am opening the system slightly.
Unless the pedal gets spongy, don't worry about doing more bleeding until you've got the leaks under control. You're not likely to get much, if any air into the system by simply loosening a fitting. It might help to find leaky fittings if you prop the brake pedal down and keep a little pressure on the lines for a while, maybe with a piece of broom stick cut off to wedge between the brake pedal and the steering wheel.
Crusing in the Passing Lane
The broom will still be useful for a shorter person.
Ed
Most of the broom handles around my shop tended to be 8" short or so- - - - -about the length of a clutch alignment tool!
well, I am no mechanic but I would get under the vehicle, clean all brake lines, then put the broom stick trick in
get back under the vehicle and see if I could see the leak, should not be that hard to do..
Redryder pix
My Hotrod
I jacked it up, removed the wheel and tightened up the two possible culprits. I leave it up on jack stands for a couple of days while it's rainy out to see if I fixed it.
I find that one needs not be in a hurry dealing with these old trucks.
the sooner you fixed them the sooner you drive em.. hope you got it fixed.. I hate leaks, so hard to find
because they can go ever where such as coolant and oil... leaking brakes should be a little easier
good luck my friend
Redryder pix
My Hotrod
