0 members (),
202
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I keep checking on my new brake lines and fittings and almost daily I notice small leaks that I have so far been successful in stopping. Should I Re-Bleed the brakes every time I fix one of these slow leaks?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Not unless you open the system up. If your just tightening the fittings each time you should be okay.ðŸ›
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I'm doing the tighten loosen tighten loosen tighten trick so I guess I am opening the system slightly.
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Unless the pedal gets spongy, don't worry about doing more bleeding until you've got the leaks under control. You're not likely to get much, if any air into the system by simply loosening a fitting. It might help to find leaky fittings if you prop the brake pedal down and keep a little pressure on the lines for a while, maybe with a piece of broom stick cut off to wedge between the brake pedal and the steering wheel. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The broom will still be useful for a shorter person.
Ed
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Most of the broom handles around my shop tended to be 8" short or so- - - - -about the length of a clutch alignment tool! Jerry
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | well, I am no mechanic but I would get under the vehicle, clean all brake lines, then put the broom stick trick in get back under the vehicle and see if I could see the leak, should not be that hard to do..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I jacked it up, removed the wheel and tightened up the two possible culprits. I leave it up on jack stands for a couple of days while it's rainy out to see if I fixed it.
I find that one needs not be in a hurry dealing with these old trucks.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | the sooner you fixed them the sooner you drive em.. hope you got it fixed.. I hate leaks, so hard to find because they can go ever where such as coolant and oil... leaking brakes should be a little easier good luck my friend Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
