Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (SandraD, baldeagle, farmallb, Peggy M), 51 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#123753 12/28/2006 12:09 AM
Junior Member
Junior Member
Im restoring a 65 Chevy. I have access to a sprayer and booth to paint the whole truck when ready, but in the meantime I work on it in my garage. My uncle said he saw someone brushing primer on some truck show on tv, using self leveling primer. Brushing on primer would help me alot as I could do one panel, one door, etc at a time, plus there would be lest waste of material. And I do not have a sprayer or compressor at home...
So, anyone heard of brushing on primer? Or self leveling primer? Would it create too many a lot of work with brush stroke marks? Anyone done it?
#123754 12/28/2006 12:26 AM
Hi Oswalds65, Welcome to the bolt!
I haven't heard of it, but then I've been out of the loop, professionally for a while. If you can't work out a compressor and a gun, then I would stick to good old fashioned spray can primer to work one panel at a time. At least it is still a spray. Brushes have always been reserved for houses in my travels.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#123755 12/28/2006 12:34 AM
Oswalds65Chevy,
I haven't done the brush deal, but have some thoughts on it. It would seem to me that any true automotive primer would be too 'fast' to paint with a brush and not leave heavy brush marks.
If it were along the lines of a RustOleum primer, which might be reduced with mineral spirits and give time to flow and level, then it wouldn't be the proper base for any automotive paint applied over it.
There are lots of things floating around in the realm of auto paints, tractor/implement paints etc...so this might be a do-able thing. Keep us posted and good luck!
Stuart
#123756 12/28/2006 1:03 AM
I am like Tomcoe. I have been out of the loop professionally for a few years. I know when I was working in a body shop one of the painters had a problem painting a car that someone had done their own primer job on. They used a spray can primer and it was incompatable with the type of finish.I think the primer was lacquer & the paint was enamel.I guess just make sure the primer base is compatable with the finish paint.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#123757 12/28/2006 1:37 AM
I've never seen it done with a brush, but I did see a tech article in Car Kuture DeLuxe a few months back were they used a roller to paint flames on an AD hood. Didn't look too bad. I'll bet you could roll the primer on easier than spraying. Besides, you're going to have to sand it anyways, so the texture won't be any trouble at all.
Bill Burmeister
#123758 12/28/2006 2:48 AM
Junior Member
Junior Member
Thats what I was thinking, It will be sanded anyway, just might make for a little more sanding.
#123759 12/28/2006 5:31 AM
There is two part epoxy primer in a spray can available now. Martin Senior was talking about it in a couple of posts. Would work better than brushing.
Paint & Body Shop moderator
#123760 12/29/2006 5:47 PM
If you go to an automotive paint store, they might have some available. There is a product in my area that is a primer, filler and sealer It can be applied with a roller , brush or spray. Its about $100 bucks a gallon. I'm going to try it out with a weenie roller.
#123761 12/29/2006 7:10 PM
They used it on TRUCKS on Powerblock TV. It's a filler/surfacer primer.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#123762 12/30/2006 5:05 AM
Goodness, what is gettin filled that needs to be rolled on? The surface should be pretty darn straight at the time of primer application.
1947 Chevy COE
#123763 12/31/2006 3:16 AM
Are you talking about a polyester primer? That is a very high filling primer which is basically like a skim coat of "bondo".
I like it, it has it place. But unless you REALLY need some filling, it should be passed on.
Most all manufacturers have it by the way. PPG, S-W and smaller companies like PCL and Evercoat.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#123764 01/11/2007 2:18 PM
I have used polyester on my truck. Should only be used sparingly. One of the nicest paint jobs i ever saw was on a harley by a local fellow (now passed on) with a brush. I don't know for sure how he primed it, but he brushed on several coats of lacquer, one at a time, hand sanded each one,progressively finer until he was just buffing it. Would be a lot of work. I have used Martin Senor spray bomb primer with good results.
#123765 01/11/2007 2:40 PM
I guess that I am a 'hack'. I have rolled it on with a small (3 inch roller from Lowes) with much success.
Thin it as recommended, roll it on, and lightly sand. I use rustoleum brand and paint a truck for under $100. Worst case is you get an '8 foot paint job'. If in the future I want a 'professional' paint job I believe I can strip this off and do it that way. I currently do not have the money.
I also use my trucks (55 2nd and 53) for work and not as trailer queens. I don't put them in competitions and have no trophies. I am fine with that.
Go for it. My 2 cents.
Dennis
#123766 01/11/2007 2:45 PM
Oh, I wish I could find a hardener for the rustoleum. It looks nice and fades the way I like it because I want the trucks to look old and used. But the paint is soft. I would like to find a hardener or a clear coat to lay on top.
I do have a large compressor and spray gun. Rustoleum, when thinned, will spray very nicely.
Dennis
#123767 01/21/2007 6:26 AM
? is do you want it done or do you want it done good and right
LEWIS
#123768 01/21/2007 7:12 PM
Ive seen guys brush that pors primer on before.
