1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
Hello
1965 chevy short step half ton
Currently running 235/75/15 on the old original white Steele 6 lug rims, like the way it sits.
I have a set of 15x8 6 lug 10 slot Oem rally's from a 73-87 GM pickup
according to "tire rack" database information I received during a call to the order line they say the 235/75 will only fit up to 7" rims and that I will need to use 235/70 for proper fit on an 8" rim.
Could someone elaborate on this protocol?
If the two widths are the same at 235 why shouldn't the 235/75 work on the 15x8 rims ?
I like the way the truck currently sits with the 235/75 tires and would rather not loose the roughly one inch in height on the 235/70 tires.
Did not really want to go lower.
Thanks for the advice
I ran 235/75 tires on 8" rims for a while before I went to wider tires. It worked. It just looked a little funny having that wide a rim and a narrow tread print.
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
