0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1237185 09/30/2017 8:30 PM
Hi, is there a number stamped on the frame of a 1956 1/2 ton Chevrolet Pickup, that is visible without removing the cab or bed? If so maybe a picture of location
Charles
there is on mine. on the top of the driver's side frame rail near the steering box. easily seen. i'm away for the weekend - i can take a pic tomorrow afternoon if you would like.
Chevrolet did not put a mark on the frame in 1956.
The Vehicle Serial Number was on a metal plate on the cab, between the hinges on the driver's side.
http://www.1954advance-design.com/chev-specs/1956-t-ser.pdf
Some members have reported that CA DMV might have stamped a code on frames in the 50s.
frame numbers started in 55.2 & 56 like so .... first prefix not added
Was that in USA & Canada, Bill?
Did the USA specification manual only mention the pillar location, but not the frame location?
Maybe that is the "hidden location" that the DMV officer was looking for on the frame of my 1954 trucks?
It was treated as a "hidden location" from 55-2nd onwards?
the frame stamp was never advertised - pictured is a US [Janesville] truck - not sure about Canada, don't recall paying attention to it on the CDN made trucks I've had
Thanks, Bill
I was editing-in the "hidden location" possibility as you were posting your explanation.
My 55.2 3100 has it on top of the frame on the drivers side.
Brian
1955.2 3100 Truck
If is by the steering box is maybe why I cant find it. a section of the frame has been torched to install a power steering box . Cut out about 9 inches then welded a plate in to bolt the box to, pretty messy job.
The 55-2 and up TF trucks all have the number stamped twice on the frame, once above the front axle and then again about 3 feet back under the cab.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, Mike
That is what the NC DMV officer told me about my 1954 trucks.
He said he would not ask me to take my Suburban body off the frame (to find those markings/codes), but I would need a bonded title (even though it had been registered in my name since 1971. He said I looked honest (but, I am lucky he did not see me in 1971).
He did take up my invite to come to my garage to see a few 54/55st Chevrolet & GMC truck frames. He then believed me, and sent/saved photos of the frame.
Tim,
Are you saying your 54's have s/n stamped on the frame?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Sorry for the confusion, Mike
"He did take up my invite to come to my garage to see a few 54/55st Chevrolet & GMC truck frames. He then believed me, and sent/saved photos of the frame." He believed my statement to him that there are/were no numbers/codes stamped on my 1954 frames.
No - there are no serial numbers stamped on my 1954 frames.
I have a 55 Cameo that was built in Flint. I checked the frame back to the front cab mount,
that was as far as I could see, this is a clean, original frame, and there are no numbers stamped
anywhere on the top or the side of the frame.
I have the GM Shop Service Manual, but other than describe how to read the numbers,
it doesn't mention anything about the serial numbers being stamped on the frame.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
the stamping started in 55, but maybe late 55, I have seen 55's without it, but never seen later frames without it ....
GM didn't advertise the frame stamping, you won't find it in any factory literature
