0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2017 Posts: 2 New Guy | | New Guy Joined: Jul 2017 Posts: 2 | I am researching floor shifters for my 56 truck. The manual says that it is a synchromesh transmission 3 speed. I am keeping the bench seat. Can anyone give me the proper name of the transmission and a shifter( B and M) Hurst and length thanks | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | dont under stand the question, what are you wanting to do with your transmission and shifter I think your question should be posted in the drive line forum ( for transmission etc )
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If your 56 truck has the original transmission it would be a Muncie model SM318. I'm not sure if any aftermarket suppliers still make a floor shift conversion specifically for your vehicle. Probably the best you can do is find a "universal" 3 speed floor shift conversion. You will likely have to modify it to clear the seat. Fred
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | If I understand your question you are wanting to convert from column shifter to floor shift. I suggest you google floor shift conversion kits and see what is on the market. The majority of those conversion shifters were marginal at best. I have one on my 1962 C10 and it’s reliable but sort of sloppy. I believe it is a Mr Gasket brand.
This thread should probably go to the HiPo forum since it deals with a modification from stock, but I will leave it here for now and see if more answers follow.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I'm with Julian on the T-5. If you are not satisfied with the worn out sloppy 3 on the tree setup, save some of that hate for floor shift conversion kit. You will likely need it. Carl
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Running a T-5 in my 37 with a 56 3.55 rear axle. You can't beat it with a stick. Can cruise 65 at 2200 RPM's - the 261 loves it!! I'm using a Hurst shifter on mine!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | If you want the 3 speed still but on the floor, why not look for a 3speed from a 47 AD? Didn't these come with a 3speed on the floor from the factory? Simple...I hope 😎 | | | | | Joined: Jul 2017 Posts: 2 New Guy | | New Guy Joined: Jul 2017 Posts: 2 | Thank you for all the help. The old saying goes' there no school like old school' and you guys hit this one out of the park. What is an "AD" | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want the 3 speed still but on the floor, why not look for a 3speed from a 47 AD? Didn't these come with a 3speed on the floor from the factory? Simple...I hope 😎 1947 closed driveshaft 1956 open driveshaft | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | My number one suggestion would be to forgo the floor shift idea and fix the issues with the column shift. They work fine when they are tightened up and adjusted properly. Also, floor shift conversions don't really make it shift faster, they just make it easier to break stuff. Fred
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Nate, the AD doesn’t pertain to your “Task Force” Body style. AD refers to “Advance Design” trucks 1947.2 to 1955.1. Hope that clears it up for you.ðŸ›
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Tim! Ah! I had a brain cramp and totally forgot about the torque tube. Could the 47 tranny output be swapped to his 56 to fit his open drive? | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I put a 3 speed floor shifter in my 1957 truck, it has an OD synchro trans.
This is what I got from Hurst:
"Hurst has two options for you;
HUU-3667271 shifter and HUU-3670010 installation kit. It is listed for a Chevelle but it will work with your transmission and the stick has a big bend for seat clearance.
HUU-5010002 is your second option. It is the Indy SSA shifter for the 3 speed and has a slightly bent stick for the seat."
I took the first option. Because it is an OD trans, I bent the shifter a bit more to make it fit, Also I installed bucket seats with a center console. I believe with a regular 3 speed, it would install closer to the front of the truck. don | | |
