| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2017 Posts: 54 | I have a 327 with 305 heads on it, and i didn't notice it when i purchased it. There is a bolt broken off flush with the mounting surface on the bellhousing part of the block. It is the one above the starter. Just wondering if it will be okay to run it with one extra or if i should get it out? It looks like it was painted over so id assume it has been run like that before. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...if you can get to it I'd take it out. A little Kroil penetrating oil, a small punch may break it loose....
...of if you can get a welder to it put a nut over it and fill it in with weld. The heat will also help screw it out.
....or drill it and re-tap it.
(these will get you to thinking.
....it WILL run without it. Reminds me of when as a teenager I'd leave the top right bolt out of the trannys! | | |
