Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Tyler Watts, Otto Skorzeny, BC59), 160 guests, and 3 robots.
Topics128,281
Posts1,058,464
Members48,490
Z
Z Offline
I'm trying to install a set of Posies super slide springs on my 49ish chassis and can't seem to get any of them to fit into the pockets. The frame has been freshly powder coated but I have cleaned the surfaces to bare metal and even ground on the sides of the springs but cannot get the (non-shackle) end into the pocket. They seem to get tight after going about halfway in as if the ears on the pocket are tapered. Am I doing something wrong? Should I just grind more off the spring eye?
You've already voided any warranty so make em fit.🛠
Probably the spring eye that is tapered from your grinding it.
The eyes will grow in width when they are rolled, A reliable
spring shop will make sure they are the correct width and
rolled perpendicular to the leaf.
dg.
Denny G
Sandwich, IL
