4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#1235811 09/21/2017 1:51 PM
I was given an old 3 wheel engine stand with a
a front caster that sort of still works.
With other bolter's pointing out that a 4 wheel
stand is the way to go an me having a little extra
money saved on the side and before the wife needs
it I am getting close to buying one. Maybe a hoist
as well.
I saw this engine stand from Northern Tools:
http://www.northerntool.com/shop/tools/product_200641860_200641860
And this engine hoist that comes with the leveler:
http://www.northerntool.com/shop/tools/product_200640934_200640934
Anybody own them, bought stuff form Northern Tools, opinions, ideas?
Thanks. Jeffrey
Northern Tools is a good company.
I am a cheapo, so I bought similar hoists/stands/leveler from Harbor Freight. I have used all of them, many times over many years, with no problems. Including pulling a 1954 235+Hydra-Matic transmission; and, rolling a 235/261 in and out-of and around a garage. Never a problem. I gave away the 1-ton hoists that were given to me (and, warned the new owners).
https://www.harborfreight.com/2000-lb-capacity-foldable-engine-stand-69521.html
I use the 2-ton leveler.
62401
I've bought a fair amount of stuff from Northern over the years. I have no complaints. It's not Snap-On by any means, but it's not Harbor Freight, either -- most of the stuff is decent and sufficient quality for the occasional user. For the most part, it's probably the best of the Chinese stuff.
For what it's worth, I have that exact same engine hoist and leveler -- we've used it many times and it is 1st rate.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Those are OK quality, not professional grades by any means, but adequate for hobby use. I'd suggest extending the length of the legs on the engine stand by about 6" or so if you have access to a welder for maximum stability with a stovebolt six mounted on the stand. Just add a 6" long piece of square tubing to the end that plugs into the upright part of the stand. I've seen one incident where an engine stand tipped over forward and injured a student's foot pretty severely- - - -nearly 100 stitches to close up the cuts, plus several broken bones. The kids had removed a fully assembled engine from the stand, attached the bellhousing and flywheel, and put it back on the stand. Dumb move, but they didn't stop to think about the extra leverage.
Sir Searchalot
Sir Searchalot
The harbor freight one would be $108 with readily available 20% coupon.
Look at Tractor Supply Company.
I looked at the Tractor Supply. Went with Northern Tools.
I am putting them together and will be using them soon.
The engine stand looks strong, 4 wheels. Looks so much
stronger and stable then the old 3 wheel stand that I was
given. Jeffrey
Big Bolt Forum Moderator
I have an old 3-wheel engine stand. I made a "T" to plug in the end where the dingle wheel is and put another pair of casters on it so, I now have a 5 wheel stand! I can pull the "T" out to get the hoist in closer and then before I move the stand, slide the "T" back in. I made the "T" when I put my 363cid 6 cylinder Dorsett diesel on it. That was one long and heavy engine!
Mike
Smart Idea. Jeffrey
Moderated by  MNSmith
