3 members (2-Ton, kbenz, MNSmith),
161
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | | | | | | Joined: Sep 2010 Posts: 2,313 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,313 | The transmissions are the same you would just have to swap the cover for the ball type torque tube connection and the yoke for the proper u joint. I see you are from Ontario may I ask were you got the gl4 trans gear oil.
| | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Sorry dude, I bought this a while ago at Walmart.com, then drove across the border to pick it up. It was King Lube brand though, FYI.
I think my question has been answered, since I would have to wait to drop the old one to rebuild it anyway. Now I just have to weigh if it's worth replacing the bearings and seals, or just do a gasket kit. | | | | | Joined: Sep 2010 Posts: 2,313 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,313 | Ok will have to wait til border opens up .You can take the top off theses transmissions and see most of the inside to check out there condition | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Hopefully I can find a thread on how to assess one of these, once I have it open. | | | | | Joined: Feb 2019 Posts: 4,480 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,480 | There are several YouTube videos that show various stages of disassembly/inspection/reassembly. Some are rather long so I didn’t watch them thru. You may find what your looking for. Do a search on “SM420’ and it will bring up several. Good luck!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Thanks, I will try that. I just ordered my gasket sets  I don't even know when I'll be ready to start it! No patience... | | |
