| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Oh wise ones of the stovebolt society. Please educate a relatively youngish person on how window swamp coolers work. Also, how well do they work.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the process is 'evaporative cooling' - the wind coming in the window is humidified - how well it works depends on the particular climate you're in, might not work as well in Missouri as in Aridzona  Bill | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Lick the underside of your wrist and then blow on it---it will feel cool even though your breath is over 90 degrees. Evaporation absorbs heat. The cooler has water in it and a mesh to hold the water and let air pass through it, where evaporation occurs, and then comes into the car as cooler air. A swamp cooler will work fairly good (cool air, not cold) in the desert Southwest or in other low humidity areas where evaporation is rapid but not at all well in high humidity areas. Used to see cars with the window cooler and a canvas water bag hung on the front bumper where the water evaporating from the damp surface cooled the water inside (slightly). Bag could also be used to top off an overheating radiator. Old enough to have lived through it.
Evan
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | They're also called "evaporative coolers"- - - - -they have a reservoir of water and it's pumped through a horsehair-like material as air blows across it. The water evaporates and cools the air- - - - -a little. They work best in very low humidity areas- - - -southwest deserts, California, Arizona, etc. If the air is too humid to evaporate much water, they just blow hot, wet air! Jerry
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Guess that explains why I've never seen one around here. If there's one thing missouri has, its copious amounts of humidity.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Highly sought after accessory by the "Low Rider" crowd.🛠ðŸ›
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Oh yeah..... not much of that around here either.
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | On FB page "Old car part swapmeet" there is a guy out of California that sells them as well as as the visors. I think he must be re-manufacturing them.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I remember seeing a metal cylinder about 12" in diameter about 20" long. Make with sheet steel. that would hang on the RF door window. The way a speaker would in a drive theater or a car hop would hang the tray on the window.
The front of the cylinder/tube was open so air would enter the tube pass over ice then the air would pass through an opening of the tube on the side near the back.
Cooled air would then enter the car.
I do not know how effective this was or how long the ice would last. Jeffrey
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I spoke with a guy that had one 2 weeks ago here at a local show. He said it made a real hot day bearable, not enjoyable, but bearable. All the things stated above about humidity he said as well. Also, you have to be moving! If you have it and are stuck in traffic, it is useless! | | | | | Joined: Nov 2012 Posts: 257 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 257 | I spoke with a guy that had one 2 weeks ago here at a local show. He said it made a real hot day bearable, not enjoyable, but bearable. All the things stated above about humidity he said as well. Also, you have to be moving! If you have it and are stuck in traffic, it is useless! No need to be moving if you have one of the coolers that is equipped with a built in fan. http://pic20.picturetrail.com/VOL1568/13678754/24528751/413548634.jpg. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There's a reason there aren't many around. They didn't work well. A few were sold because that's all that was available at the time. I bought one a few years ago to display with my '38 at shows but ended up selling it because it didn't fit the smaller windows of my car.
