0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1233712 09/06/2017 7:04 PM
Just getting ready to reinstall my pan and I see one of the long side gaskets has a larger, squarish end on it, compared to the other 3 ends. Does anyone know where this blocky end should be on a 216?
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
I arrange them to get the best match with the holes. I usually have to trim the square ends. I use RTV in the corners to make sure that the side seals and the end seals wotk together.
1951 1 Ton Completed
Here's a pic of the end in question, if that helps...
https://photos.app.goo.gl/EZYxFf257cwgzmwD3
More images
Well, I found this on the web with pics that appear to have it on the front passenger side:
http://www.inliners.org/ubbthreads/...PSESSID=24f5b77c96c07caabd32d95cde645874
I will give it a try.
More images
Good find Goach. Makes sense since there is more meat on the block on that side.
