| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | Just getting ready to reinstall my pan and I see one of the long side gaskets has a larger, squarish end on it, compared to the other 3 ends. Does anyone know where this blocky end should be on a 216?
Thanks! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I arrange them to get the best match with the holes. I usually have to trim the square ends. I use RTV in the corners to make sure that the side seals and the end seals wotk together. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Good find Goach. Makes sense since there is more meat on the block on that side.
