1 members (Youngin' Tut 59),
123
Mod | | | Forums66 Topics128,201 Posts1,057,276 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | Back during the summer and fall of '14 I was working on replacing the brake system (master and slave cylinders, shoes, lines...all of it) on my '69 C-10. Had her on jack stands and all was going well. I was and still am a complete newbie with no experience except what I've learned by doing, not even having done anything beyond changing oil until I started fooling with the truck. With the brake project only partially complete, life interfered and Maude (my truck) has sat idle since. It's been at least 2 years since the engine ran, which was fine before the lapse. I tried to start it a few months ago and got nothing...and I mean nothing. Not only was there no starter action, but no dash lights, no cab lights, nothing with the key switched on. I charged and checked the battery by jumpering it directly to the horn, which screamed loudly. Does anyone have any particular thoughts on where an electrical issue may have developed? The ignition switch is original, and wobbly. As far as I know, the starter is also original. The whole battery-cable-goes-stratight-to-the-starter thing I don't really understand.
Darren | | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | You're getting back to it. That's good. You know if was running fine two years ago, so I'd start with that. Make sure all of your connections from the battery are clean, including ground connections to the engine and frame. Critters have a way of munching on things we wish they wouldn't. After you know you have a strong battery and contacts are good, you should get something.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | Thanks, Victor, for your thoughts. That's a place to start. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Toss the old battery. Honking a horn is not the way to test for load. If it sat for 2-3 years it is junk. Then do as Victor said.ðŸ›
| | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | "We test- - - -not guess!" Sun Electric Co. put that slogan on all their test equipment over 60 years ago and it's still just as right today. Take the battery out and have a parts store such as O'Reilly's or Advance Auto Parts test it. Chances are it won't pass the load test, but give it a chance for a blindfiold and a last cigarette before you call the firing squad to attention. Most likely, the cable clamps where they meet the battery have corroded and all they need is a good scrubbing with a battery post and clamp cleaner- - - -that tool costs a small fraction of what a battery does. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You would want a new battery if you are planning on revamping your interest in driving it. The old battery is a valuable exchange core. Take it with you.
Clean the cable end clamps that go on the battery or get new cables. As said. Then try starting, check the oil pressure immediately, report what happens next. No pressure? Stop motor.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | I just finished job #2 for the day, walked outside, hooked up the battery charger, switched on the key, and...got the red glow of the generator and oil pressure lights. I can switch on the dome light and headlights. Of course turning the key to start only dims the aforementioned lights. But the electrical connection issue is apparently something jiggle-able. | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | CLEAN THE BATTERY CABLES!
Your symptoms are the classic ones I've seen for over 50 years.
Somebody else take over- - - - -the only good thing about beating one's head against a brick wall is that it feels so good when you stop! Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes, hope you have cleaned them. Otherwise the draw is too much for the corrosion to carry. You need to clean the battery posts, then take battery in for a new one, then buy new cables. (that's a joke). Did you get a click? or starter rotated? or what. If you want help without 50 posts, describe what is happening. Your post, which are typical of inexperienced persons, are not definitive. Get a new battery and get new cables and things will start to fall in place. We can't diagnose the patient until there is a heartbeat. The motor won't start from a glow. This is not to spend your money foolishly but would be done on an old truck as normal maintenance after sitting. Batteries won't tolerate sitting, they dry out and when asked to rejuvenate, it's Kings X.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | HRL, Bartamos and the others who try to help become frustrated and a bit testy when the advice given is ignored. Do as suggested then report back to us letting us know how well it runs. If it doesn't start then the collective minds will slap their foreheads in amazement and start over. We are here to help but you have to be willing to help us help you.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I was in your exact position a number of years ago. Old truck, no tools, no time, no experience. No brakes.Worked through all of that (no) stuff by slow and steady method and with the help of good advice provided in simple bite sizes. You will get traction (so to speak) at your pace. We will be patient and chime in when time and info suggest. To this point advice is good. Likely only weak battery and bad connections. Ground circuit is critical. If ground point has developed corrosion over the time it will need a good wire brushing. Once we confirm good electricity we will troubleshoot Ingintion side if required.
Dothan? Made a quick run through there with fly safety. We have things in common. Hambone | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | Well, gents, last night I left the charger on the battery (of course) and a bit ago had time to inspect and clean the battery posts and cable ends. When I tried to crank her, that starter jumped to life, but there was no ignition. I gave her a shot of starter fluid and with the next try, for a second or two, the turn-over rhythm quickened a bit. There was still no real "ignition" action then, or with subsequent attempts. But that's a concern for another day, hopefully the weekend. The electrical connection issue is settled and I thank one and all for input. I wouldn't have thought that cleaning such that didn't even look dirty or corroded would cause such a difference! | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Now- - - - -clean or change the points.. They get an almost invisible coating of oxidation that results in a weak spark or none at all. Jerry
