5 members (Hotrod Lincoln, papas52, Gdads51, Peggy M, 1 invisible), 102 guests, and 4 robots.
Topics128,165
Posts1,056,989
Members48,458
Our 1952 Carryall has a combination of wonderful patina as well as some rust. It lives in California, so not too much of an issue with it progressing.
I am seeking suggestions on how to preserve the patina - I don't think clear coat is the answer, but would love suggestions.
There is some surface rust, I was thinking of knocking it down with CLR and some 000 steel wool..
Any help is very much appreciated!
Lisa
1952 Chevy Carryall in completely original condition
Pulled out of a barn in Colorado high desert
Do you get much salted air from the ocean?
Do you get much rain/snow (mountains)?
Rub the sheet metal down every year with WD-40?
I was able to polish the finish to shine, and then wax it. I've had lots of comments about how good it looks, some even think I did have it cleared.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
CLR is great. It removes rust stains and oxidation from paint as well as some of the rust. My '53 was really bad so I spent some time scrubbing down the worst rusty spots with a green Brillo pad and lots of water. I then washed the whole thing with CLR.
I live in southern Iowa- right in the rust-belt. 10 and 15 year old trucks around here have rust holes you can stick your hand through, so slowing or stopping the rust was important to me. I didn't want to clear-coat it because that looks unnatural- kind of plastic- and it really darkens the rust. Car wax works OK on good paint but can be hazy on old paint and turns white on rust and scratches. My solution was to use furniture paste wax. You can adjust the level of shine, it's invisible on rust and rubber, and it's more water repellent than car wax.
If you look in the upper right hand corner of my photo you'll see rust free bare metal. It's been that way for about nine years now with no signs of rust.
Have you tried Gibbs metal polish? A lot of guys with bare steel on their vehicles seem to like the stuff, and it's supposed to inhibit corrosion.
~ Dave
Is there really any thing you have to do to preserve the look. After all its been achieving that look naturally after many years....just let it continue if rust through is not evident.
Ralph
