| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I just went out to my truck to see how mine look (they are exposted being the inner panel is removed) and they look very nice so I won't be getting these on eBay. But boy, what a deal if you needed them.
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Brian do you know if any repop's ever had the hinge pocket indentation like these ones? To me that's a dead giveaway the cab's been repaired but to use these should be sweet for fit and originality for somebody. Thanks for the great posts by the way,I've learned alot from your expertise.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Thanks for your kind words Curt, I don't know what is available anymore than the complete side cowl that goes up TO that hinge area but not including it. I have to assume the pocket is available being that would be a spot for rust and damage from the hinge. Your cowl is welded to the top of the cowl right there above where the hinge bolts on and it would be a prime place for rust IF any muck got trapped there over the years above the hinge.
Brian
