2 members (55shaker, Hotrod Lincoln), 137 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
Guys-If i have my truck completely dissasembled, and each piece of sheet metal is primered up and fixed up-when is the best time to mount the sheet metal-to be more specific in that question-see im wondering should the parts be put on the truck and then painted the final color or painted and then put on. Reason i wonder is because if i go to put the sheet metal on and adjustments have to be made for whatever reason-wont that mark up the new paint job? :confused:
Tell me how you would do it...
Disassemble, do body work and prime, reassemble, make the adjustments, disassemble, paint and reassemble.
you could reassemble and then paint but just make sure you paint your janbs and all covered edges before.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
