2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Guys-If i have my truck completely dissasembled, and each piece of sheet metal is primered up and fixed up-when is the best time to mount the sheet metal-to be more specific in that question-see im wondering should the parts be put on the truck and then painted the final color or painted and then put on. Reason i wonder is because if i go to put the sheet metal on and adjustments have to be made for whatever reason-wont that mark up the new paint job? :confused:
Tell me how you would do it... | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Disassemble, do body work and prime, reassemble, make the adjustments, disassemble, paint and reassemble. | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | you could reassemble and then paint but just make sure you paint your janbs and all covered edges before. | | |
