| | | Forums66 Topics128,157 Posts1,056,878 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12318 12/23/2004 7:09 AM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | With Chevy 235 becoming increasingly difficult to find, I buy them when a chance comes along.
I bought one, 55 - 57 casting, and brought it home from San Pedro with crossed fingers. Not too bad except one cylinder presents a challenge.
The previous owner allowed water to enter the carb which ended up in the number one cylinder causing very minor rust damage. This damage, although minor, is measured at .012 to .015 in depth.
Real problem is this engine is stamped bored to .040 and normal limit is .060 overbore. Taking it out to .060 will not quite clean out all of the damage, minimal left but that is unacceptable.
I am told you can take the 235 out to .080 over like the big brothers. However, over the decades, this has never been my personal practice. I am concerned the water jacket will be too thin which will cause overheating problems.
My first choice is to sleeve all cylinders and bore to standard. This will present no problems.
Still, I am curious about a .080 overbore with a 235 cubic inch (not the larger engines) and what effects where noted.
Anyone have any direct experience with this? Positive or negative outcome?
Billyray | | |
#12319 12/23/2004 7:49 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have built several .080 over 235s one built quite radical. None have had any problems.
See the USA in your vintage Chevrolet! My Blog | | |
#12320 12/23/2004 8:04 AM | Joined: Dec 2004 Posts: 12 Junior Member | | Junior Member Joined: Dec 2004 Posts: 12 | Thanks Dave. Heat is not usually a problem with the 235 engines. I run "desert" radiators which is just a fancy term for 4 core radiators.
Compression and breath draw will be slightly greater but I don't think will be a problem. Stock compression is very low to begin with.
Dave, do you have a favorite parts source for those .080 pistons and rings?
Billyray | | |
#12321 12/24/2004 4:06 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I get most of my parts from Northern Auto Parts. www.northernautoparts.com
#12322 12/24/2004 5:31 AM | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | My usual parts source is Internal Engine Parts Warehouse, in Nashville, TN. I think their corporate headquarters is in Mississippi, and they distribute parts all over the southeast. Good people, and they have a good jobber's discount.
Doing a full sleeve job will be expensive, unless you've got your own boring equipment. I salvage trashed-out 4-bolt main bearing 350's that way, and run them in round track cars at over 600 HP in some applications. Some of my competitors GIVE me blocks they think are junk, and I recycle them and beat them with their own scrap iron! 80 over on a 235 shouldn't be a problem, however; those blocks have a lot of iron in them! Jerry
